Seite 8 von 9
Re: Raspberry Pi installieren: Raspberry Pi OS (ehemals Raspbian)
Verfasst: 09.04.2021, 16:59
Anleitung und Bilder an neues Image angepasst.
Download wie immer hier:
Download
raspberrypi.org hat geschrieben:2021-03-04:
* Thonny upgraded to version 3.3.5
* SD Card Copier made compatible with NVMe devices; now built against GTK+3 toolkit
* Composite video options removed from Raspberry Pi 4 in Raspberry Pi Configuration
* Boot order options in raspi-config adjusted for more flexibility
* Recommended Software now built against GTK+3 toolkit
* Fix for crash in volume plugin when using keyboard could push value out of range
* Fix for focus changing between windows in file manager when using keyboard to navigate directory view
* Fix for Raspberry Pi 400 keyboard country not being read correctly in startup wizard
* Armenian and Japanese translations added to several packages
* Automatically load aes-neon-bs on ARM64 to speed up OpenSSL
* Raspberry Pi firmware fcf8d2f7639ad8d0330db9c8db9b71bd33eaaa28
* Linux kernel 5.10.17
Vollständige Release Notes:
Link
Info zur obigen Änderungsliste:
Obwohl das Image nur wenige Tage alt ist, wird per
wieder ein größeres Update vieler Pakete eingespielt (bei der Full Version).
Daher können oben genannte Pakete bereits wieder höhere Versionsnummern tragen (z.B. Thonny ist dann 3.3.6).
Verfasst: 30.05.2021, 17:02
Download
raspberrypi.org hat geschrieben:2021-05-07:
* Chromium upgraded to version 88.0.4324.187
* NuScratch upgraded to version 20210507
* Node-RED upgraded to version 1.3.4
* pigpio upgraded to version 1.79
* Thonny upgraded to version 3.3.6
* Icelandic and Italian translations updated for several packages
* piclone: Remove hiding of application in other desktops
* agnostics: Remove hiding of app in other desktops
* rp-bookshelf:
- Remove hiding of app in other desktops
- GTK+3 version
* lxplug-bluetooth:
- Fix some memory leaks
- Add authorisation dialog required by some BT-LE pairings
* alsa-utils: Add custom init files for bcm2835 on Raspberry Pi to set volume correctly
* rp-prefapps: Remove hiding of app in other desktops
* OpenSSH and OpenSSL speed improvements
* Install gpiozero in lite images
* Raspberry Pi firmware 518ee7c871aaa9aaa88116953d57e73787ee6e43
Link
Verfasst: 20.11.2021, 21:13
Anleitung und Bilder an neues Image angepasst und Info zum "WLan Problem bei Vorabkonfiguration".
Download
raspberrypi.org hat geschrieben:2021-10-30:
* Based on Debian version 11 (bullseye)
* Desktop components (lxpanel and all plugins, libfm, pcmanfm) now built against GTK+3
* Applications (piwiz, pipanel, rc_gui, lxinput) now built against GTK+3
* PiXflat GTK+3 theme updated with numerous changes to support the above
* GTK+3 : toolbar icon size setting added
* GTK+3 : ability to request client-side decoration on windows added
* GTK+3 : setting for indent for frame labels in custom style added
* mutter window manager used instead of openbox on devices with 2GB or more of RAM
* mutter : title bar icon behaviour and appearance modified to match openbox
* mutter : additional keyboard shortcuts added
* mutter : various performance enhancements
* mutter compatibility added to screen magnifier
* Numerous changes to Appearance Settings application to support GTK+3 and mutter
* Updater plugin added to lxpanel to detect and install software updates
* File manager view options simplified to either list or icons, with separate menu option for thumbnails
* New file manager toolbar icons
* KMS used as default display driver
* Modifications to HDMI audio output selection to support the above
* xcompmgr enabled when openbox is running under KMS
* New default camera subsystem based on libcamera
* New camera demo applications (libcamera-still and libcamera-vid) have replaced raspistill and raspivid
* Legacy camera subsystem removed from 64-bit RPi OS (still available on 32-bit)
* Chromium upgraded to version 92.0.4515.98
* VLC media player upgraded to version 3.0.16
* Spurious drive removal warning after use of SD card copier removed
* Bookshelf application now includes Custom PC magazine
* Various translation updates - Italian, Korean, Polish, German, Armenian
* Startup wizard now installs Japanese fonts if needed
* Progress and information dialog boxes for lxpanel plugins now common to lxpanel, rather than in individual plugins
* Icon handling code for lxpanel plugins now common to lxpanel
* Package with 4K version of Raspberry Pi wallpaper added to Recommended Software
* Python Games and Minecraft removed from Recommended Software - neither is compatible with bullseye
* Bluetooth pairing and connection dialogs updated for compatibility with more devices
* Bluetooth devices always disconnected before removal to speed up removal process
* Bluetooth pairing dialog now only shows devices which offer services which are usable by Pi
* Separate Bluetooth unpair dialog removed - unpair now an option for each individual device
* Bug fix - mutter : header bar colours not updating when theme is changed
* Bug fix - GTK+3 : tooltips being displayed incorrectly at bottom of screen
* Bug fix - lxpanel : crash when using keyboard shortcut to enable magnifier when magnifier not installed
* Bug fix - lxpanel : lockup in Bluetooth plugin when connecting to certain devices
* Bug fix - lxpanel : discoverable mode icon could get out of sync with underlying Bluetooth system state
* Bug fix - piwiz : missing cities in timezone list
* Bug fix - piwiz : country-specific language packages not being installed
* Bug fix - bookshelf : now waits for longer between packets before timing out
* Bug fix - accented characters now displayed correctly in localisation dialogs
* Raspberry Pi firmware e2bab29767e51c683a312df20014e3277275b8a6
* Linux kernel 5.10.63
Link
Verfasst: 28.01.2022, 21:32
Anleitung und Bilder an neues Image angepasst und Info zum "WLan Problem bei Vorabkonfiguration" entfernt, da wieder ok.
Download
raspberrypi.org hat geschrieben:2022-01-28:
* rc_gui - add combo box to allow resolution to be set for VNC connections
* rc_gui - camera interface switch removed
* lxpanel - remove appearance settings from preferences dialog; instead add menu option to open general Appearance Settings application
* lxpanel - add ellipses to menu items which open dialogs
* lxinput - read current mouse acceleration directly from xinput
* lxinput - use device IDs rather than names to cope with devices changing when powered-down
* lxinput - remove redundant changes to openbox config file
* plymouth - set KillMode to mixed to suppress warning message
* raspi-config - add option to switch composite video
* raspi-config - add option to switch to legacy camera mode
* raspi-config - add option to set resolution for headless connections
* raspberrypi-ui-mods - disable mutter when VNC server is running and fall back to openbox
* pipanel - add command-line option to open on arbitrary tab
* lxplug-network - suppress ’scan received’ logging message
* raspberrypi-ui-mods - set hover colour for taskbar items based on taskbar colour, not system highlight colour
* Legacy camera applications and libraries reinstalled
* Bug fix - lxinput - lxsession config file not being written on first attempt
* Bug fix - lxinput - set timer for file write to prevent slider slowing down
* Bug fix - lxinput - write values to gsettings as well as xinput and xsettings to take effect within mutter
* Bug fix - lxinput - fix failure to parse and write non-English numeric formats
* Bug fix - arandr - various fixes to parsing of non-standard EDID blocks to enable model and serial to be correctly extracted
* Bug fix - arandr - refresh rate calculated to 3 decimal places for monitors which require it
* Bug fix - arandr - enable setting of left and right orientation
* Bug fix - arandr - add compatibility with new touchscreen driver
* Bug fix - arandr - apply settings correctly to DSI and composite displays
* Bug fix - lxplug-magnifier - fix crash when opening preferences without required magnifier package installed
* Bug fix - piwiz - launch screen reader install prompt as a new process to prevent audio lockups crashing wizard
* Bug fix - lxpanel - not loading some plugins (cpufreq, minimise all windows) due to icon loading code not compatible with GTK+3
* Bug fix - gtk+3 - disabled new GDK touch events to enable double-clicks to be detected on touchscreen
* Bug fix - xrdp - included backports from bookworm version of xrdp and xorgxrdp to restore window frames with mutter over xrdp connections
* Update various translations
* udisks2 added to lite image
* mkvtoolnix added to lite image
* 7z and zip support added to lite image
* gnome-keyring added to desktop images
* Raspberry Pi firmware c6d56567ff6ef17fd85159770f22abcf2c5953ed
* Linux kernel 5.10.92
Link
Verfasst: 03.02.2022, 19:11
Zwei weitere Images (64 Bit) genannt und verlinkt.
Verfasst: 04.02.2022, 21:34
Anleitung und Bilder an neues Image (64 Bit) und neuen Imager (mit erweiterten Optionen) angepasst.
Download
Änderungen neues Image (hier 64Bit Desktop Version):
* Policykit CVE-2021-4034 fix
* Legacy camera applications and libraries reinstalled (32-bit only)
Link
Verfasst: 11.04.2022, 00:21
Download
raspberrypi.org hat geschrieben:2022-04-04:
* Default "pi" user has been removed; the first-boot wizard enforces the creation of a new user account
* rename-user script added to allow existing users to be renamed by temporarily rebooting to cut-down first-boot wizard
* Overscan now managed by xrandr under KMS, can be set independently for both monitors, and takes effect on the fly rather than requiring reboot
* GTK3 switch control now used in place of paired radio buttons throughout
* piwiz - first-boot wizard now runs in a separate session as a different user with different graphics
* piwiz - first-boot wizard now has automatic pairing for discoverable Bluetooth mice and keyboards
* lxinput - keyboard delay and repeat settings now persist across reboots under mutter
* raspi-config / rc_gui - removed pixel doubling option when KMS driver in use
* raspi-config - removed composition manager option when legacy driver in use
* arandr - restored support for interlaced displays
* mutter - implemented more intuitive window and application cycling behaviour
* pi-greeter - rebuilt for GTK3
* Bug fix - graphical corruption in system tray icons
* Bug fix - desktop items vanishing when dragged
* Bug fix - terminal windows not focussed correctly when launched
* Bug fix - crash after multiple update checks in updater plugin
* Bug fix - Raspberry Pi keyboard auto-detect by wizard was broken in previous release
* Bug fix - spurious "connected" dialog box shown when reconnecting to Bluetooth LE devices on boot
* Support for experimental Wayland backend added - can be enabled as an advanced option in raspi-config
* Various small bug fixes and graphical tweaks
* Chromium upgraded to version 98.0.4758.106
* FFmpeg HW acceleration improved
* OpenJDK 17 now defaults to 'client' JVM for ARMv6 compatibility
* Raspberry Pi firmware 69277bc713133a54a1d20554d79544da1ae2b6ca
* Linux kernel 5.15.30
Link
Re: Raspberry Pi installieren: Raspberry Pi OS (Anleitung im Umbau)
Verfasst: 31.07.2022, 19:38
Anleitung wird auf Windows / macOS / Ubuntu nach und nach erweitert.
Verfasst: 09.08.2022, 17:33
Anleitung soweit angepasst / SSH Win/Mac/Ubuntu hinzugefügt.
Verfasst: 07.09.2022, 22:11
Download
raspberrypi.org hat geschrieben:2022-09-06:
* lxpanel - new main menu plugin with text search
* lxpanel - new separate audio input plugin with microphone volume and input select
* lxpanel - keyboard shortcuts to open wifi and bluetooth plugins added
* lxpanel - notifications now shown with short delay after startup and between each
* rc_gui - only allows valid hostnames to be set
* piwiz - no longer allows "root" as a user name
* gtk3 - menus can now be resized after being drawn
* raspi-config - option to switch between dhcpcd and Network Manager added
* lxpanel - new network plugin compatible with Network Manager added
* piwiz - compatibility with Network Manager added
* Bug fix - 100% CPU usage in file manager when desktop item unmounted
* Bug fix - window manager was preventing switching between international keyboard layouts
* Bug fix - system tray redrawing made more robust
* Bug fix - translations not being shown in various lxpanel plugins
* Bug fix - updater plugin failing on x86 images
* Bug fix - force power on for Bluetooth hardware when unblocked with rfkill
* Bug fix - message boxes in rc_gui not centred correctly
* Bug fix - switching sessions between Wayland and X11 made more robust
* Bug fix - switching of ALSA devices in raspi-config made compatible with third-party devices
* Install NetworkManager (disabled)
* Install OpenJDK 17 rather than OpenJDK 11 on full images
* Install picamera2
* Format the root partition with the metadata_csum option
* Format the boot partition with 4 sectors per cluster for a slight performance boost
* Remove 'flush' mount option from the boot partition
* Raspberry Pi firmware 48cd70fe84432c5d050637b61e4b7b9c831c98bf
* Linux kernel 5.15.61
Link
