Seite 7 von 9
Re: Raspberry Pi installieren: RASPBIAN Buster (+Full +Lite)
Verfasst: 29.02.2020, 16:15
Anleitung und Bilder an neues Image angepasst.
Download wie immer hier:
Download
raspberrypi.org hat geschrieben:2020-02-13:
* Raspberry Pi Configuration - screen blanking setting disabled if Xscreensaver is installed
* Bug fix - switch to turn off VNC server in Raspberry Pi Configuration has no effect
* Bug fix - fix %20 characters in file names
* Linux kernel 4.19.97
* Raspberry Pi firmware 9a34efbf2fc6a27231607ce91a7cb6bf3bdbc0c5
- gencmd: Fix measure_clock name for CLOCK_OUTPUT_108
- mmal isp: Remote alignment requirements for RGB24 formats
- Add missing flags for VC_IMAGE_PROP_YUVUV_4K_CHROMA_ALIGN
- platform: Compromise on gpu overclock settings
Vollständige Release Notes:
Link
Verfasst: 27.03.2020, 03:15
Anleitung von Win32 Disk Imager auf Raspberry Pi Imager geändert.
Verfasst: 28.05.2020, 11:43
Download
raspberrypi.org hat geschrieben:2020-05-27:
* Added Bookshelf application
* Added Raspberry Pi Diagnostics application
* Added magnifier plugin to taskbar - needs magnifier application installed from Recommended Software to enable
* Added Magnifier application to Recommended Software
* Added marketing questionnaire as initial Chromium tab
* Version 0.25 of Scratch 2 included - uses external application to access IMU on SenseHAT
* Version 1.0.5 of Scratch 3 included - uses external application to access IMU on SenseHAT
* Version 32.0.0.371 of Flash player included
* Version 1.0.6 of Node-RED included
* Version 6.7.1 of VNC Server included
* Version 6.20.113 of VNC Client included
* Internal audio outputs enabled as separate ALSA devices
* MagPi preinstall removed and replaced with Beginners Guide
* MagPi weblink removed from main menu
* Chromium made default application for PDF files
* Common icon loading code for lxpanel plugins used
* Italian translations added
* Initial move of mouse pointer to menu button disabled
* Padding at left of menu button removed
* Focus behaviour changed so that focus moves to desktop if no windows are opened - improves reliability of Orca screen reader
* Bug fix - focus bug in volume plugin
* Bug fix - keyboard repeat interval bug in Mouse & Keyboard Settings
* Bug fix - battery detection bug in battery plugin
* Bug fix - spurious active areas on taskbar when plugins are hidden
* Bug fix - occasional crash in file manager on file selection
* Disk ID is now regenerated on first boot
* Updated udev rules
- Remove unused argon rule
- Add vcsm-cma to video group
- Add pwm to gpio group
* i2cprobe: More flexible I2C/SPI alias mapping
* Raspberry Pi firmware 21e1fe3477ffb708a5736ed61a924fd650031136
* Linux kernel 4.19.118
Link
Verfasst: 03.06.2020, 14:08
Info zur Korrektur der Audioschnittstelle hinzugefügt.
Verfasst: 28.08.2020, 21:00
Download
raspberrypi.org hat geschrieben:2020-08-20:
* raspi-config - added selection of boot device order
* raspi-config - added selection of boot EEPROM version
* SD Card Copier - copy is now immediately aborted if drives are connected or disconnected while copying
* Version 32.0.0.414 of Flash player included
* User feedback survey removed from first run of Chromium
* Recommended Software - now allows multiple install and reinstall operations without having to close between each one
* Bug fix - misleading file browser from panel menu icon selection dialog - icons must now be in icon theme rather than arbitrary files
* Bug fix - items in main menu not being translated
* Bug fix - raspi-config not detecting audio devices in non-English locales
* Bug fix - Bookshelf claiming no disk space in non-English locales
* Bug fix - failed installation of both 32 and 64 bit versions of packages by Recommended Software on 64-bit images
* Italian translations added (thanks to Emanuele Goldoni and the Italian translation team)
* Raspberry Pi firmware ef72c17bcaaeb89093d87bcf71f3228e1b5e1fff
* Linux kernel 5.4.51
Link
Re: Raspberry Pi installieren: Raspberry Pi OS (ehemals Raspbian)
Verfasst: 27.09.2020, 01:21
Einige inzw. überflüssige Hinweise entfernt.
Verfasst: 28.11.2020, 21:31
Durch diverse Updates hat sich die Menüstruktur in raspi-config komplett geändert, Anleitung angepasst.
Verfasst: 07.12.2020, 15:47
Download
raspberrypi.org hat geschrieben:2020-12-02:
* PulseAudio now included and running by default
* Bluealsa Bluetooth interface removed - Bluetooth audio is now handled by PulseAudio
* LXPanel volume control plugin replaced with PulseAudio version
* Version 84.0.4147.105 of Chromium web browser included
* Version 3.3.0 of Thonny included
* Version 32.0.0.453 of Flash player included - note that this will be the final release of Flash, as it is end-of-lifed at the end of 2020
* CUPS printer system included, along with system-config-printer CUPS GUI and HP printer drivers
* raspi-config menu structure rearranged to match Raspberry Pi Configuration tabs
* Control for GPIO-connected fans added to raspi-config and Raspberry Pi Configuration
* Control for power / activity LED on Pi 400 and Pi Zero added to raspi-config and Raspberry Pi Configuration
* Improved screen reader voice prompts in several applications
* Added ctrl-alt-space shortcut to install Orca screen reader at any point
* Low voltage warnings added to battery monitor plugin
* Magnifier plugin zoom can now be changed with scroll wheel when pointer is over icon
* Change to notification popups - now will only close when clicked on directly, not by clicking anywhere
* Bookshelf now made compatible with translated versions of books and magazines, and will offer translated versions where available, based on system language setting
* Bug fix - crash in CPU temperature plugin when throttling detection fails
* Bug fix - if Orca is running, shutdown commands and shutdown dialog will force kill it to prevent it locking up the reboot or shutdown process
* Various additional language translations added
* Various minor bug fixes and UI tweaks
* Raspberry Pi firmware b324aea801f669b6ab18441f970e74a5a7346684
* Linux kernel 5.4.79
Link
Verfasst: 13.01.2021, 18:26
Download
raspberrypi.org hat geschrieben:2021-01-11:
* Chromium version 86.0.4240.197 included
* Screen reader support enabled in Chromium
* Adobe have end-of-lifed Flash Player, so it has been removed
* Scratch 2 required Flash, so it has been removed
* Added Epson printer drivers
* Added timeout to hide messages from USB device monitor after 5 seconds
* Bug fix - PulseAudio output was in mono
* Bug fix - brief audio interruptions at start of playback in VLC
* Bug fix - old ALSA output settings being used instead of PulseAudio settings by some applications
* Bug fix - crash in PulseAudio volume controller when used on multichannel devices
* Bug fix - battery monitor failing to load on x86 platforms
* Bug fix - setting of password in startup wizard failed if language was changed
* Bug fix - Chromium video playback lockup on small number of devices
* Bug fix - Chromium Google Maps 3D view artefacts
* Slovak, Italian and Norwegian translations updated
* Raspberry Pi firmware 70f1581eec2c036b7e9309f1af41c651fb125447
* Linux kernel 5.4.83
Link
Verfasst: 25.03.2021, 15:54
Anleitung etwas aufbereitet und inzw. überflüssige Passagen entfernt.
