Raspberry Pi installieren: RASPBIAN Stretch (+Full +Lite)
Anleitung und Bilder an neues Image und Pi 3B+ angepasst und getestet.
Hardwareliste angepasst (Pi 3B+ hinzugefügt).
Anleitung und Bilder an neues Image angepasst, getestet und wpa_supplicant.conf (WLAN) angepasst.
Neues Raspbian Image vorhanden, Anleitung wird bald angepasst:
raspberypi.org hat geschrieben:2018-06-27:
- New first-boot configuration wizard added
- Recommended Software installer added
- Bluej, Greenfoot, NodeRED, Claws Mail, VNC Viewer removed from image - can now be installed from Recommended Applications
- Qpdfview PDF viewer installed instead of Xpdf
- Version 65.0 of Chromium browser included, with latest Flash player
- Volume up / down keys now change by 5% increments and affect currently-selected output device rather than internal device only
- Network plugin now remembers previously-entered WiFi network passwords when prompting for reconnection
- Serial port and serial console can now be switched separately in Raspberry Pi Configuration
- Lxkeymap keyboard language setting application removed - replaced with dialog within Raspberry Pi Configuration
- Wifi country and keyboard language setting dialogs in Raspberry Pi Configuration now callable from other applications
- New version of Piboto font included to render with correct weight under some rogue applications
- Reconnection to Bluetooth audio devices on reboot improved
- Disable click-to-rename behaviour in file manager if single-click selection enabled
- Appearance Settings dialog makes config changes to some Qt files to match selected theme
- MIME file type associations improved
- Multiple desktop management options removed from mouse middle-click menu
- Menu shortcuts to Raspberry Pi website amended
- Python 2 IDLE menu link removed
- Sample Magpi PDF installed in /home/pi/MagPi
- Various minor tweaks, bug fixes and appearance changes
- Bluetooth updates
- Firmware with Bluetooth 4.2 features
- SCO profile suppot added via bthelper.service- Linux kernel 4.14.50+
- Raspberry Pi firmware 748fb17992426bb29d99224b93cb962fefbdc833
Anleitung und Bilder an neues Image angepasst und getestet, Info zu 128GB SD Card hinzugefügt.
Anleitung und Bilder an neues Image angepasst und getestet, kleinere Änderungen, Updatebereich komplett überarbeitet.
raspberrypi.org hat geschrieben:2018-10-09:
* In startup wizard, assign keyboard to country as per Debian installer recommendations
* In startup wizard, add option to use US keyboard in preference to country-specific option
* In startup wizard, show IP address on first page
* In startup wizard, check for existing wifi network connection and show it if there is one
* In startup wizard, install language support packages for LibreOffice and other applications
* In startup wizard, improve operation with keyboard only and no mouse
* Password change in Raspberry Pi Configuration and startup wizard now works properly if passwords contain shell characters
* Battery indicator plugin modified to cope with Pi-top hardware monitor crashing
* Networking plugin hides wifi password characters by default
* In Scratch 2 GPIO plugin, set pin from dropdown list rather than free text
* In Scratch 2 SenseHAT plugin, swap x and y axis values for LED array
* Include latest Adobe Flash player (31.0.0.108)
* Include latest RealVNC Server (6.3.1)
* Include libav-tools
* Include ssh-import-id
* Removed Mathematica
* Merge in latest third-party code for Bluetooth ALSA interface
* Add ability to prevent software update changing configuration files, by creating ~/.config/.lock file
* Various other small bug fixes, tweaks and changes to text
* Make dhcpcd work with 3G devices
* Add hw acceleration to ffmpeg
* Improved WiFi-BT coexistence parameters
* Run fake-hwclock before systemd-fsck-root
* Raspberry Pi PoE HAT support
* Linux kernel 4.14.71
* Raspberry Pi firmware 5b49caa17e91d0e64024380119ad739bb201c674
Hardwareliste angepasst (Link für Gehäuse für Pi Zero hinzugefügt).
Neues Image erschienen, Anleitung wird die kommenden Tage getestet und ggf. angepasst.
Die Foundation hat zudem in der History der Vorversion (!!) nachträglich noch den Vermerk eingefügt, dass der neue Raspberry Pi 3A+ bereits dort unterstützt wurde.
Außerdem existieren jetzt 3 Images:
https://www.raspberrypi.org/downloads/raspbian
Download wie immer hier:raspberypi.org hat geschrieben:Raspbian Stretch with desktop and recommended software
Image with desktop and recommended software based on Debian Stretch
Image with desktop based on Debian Stretch
Raspbian Stretch Lite
Minimal image based on Debian Stretch
raspberrypi.org hat geschrieben:2018-11-13:
* Two versions of image created - "base" image has no optional software packages included; "full" image has all optional packages
- Removed from "base" image - LibreOffice, Thonny, Scratch, Scratch 2, Sonic Pi, Minecraft, Python Games, SmartSim, SenseHAT Emulator
- Added to "full" image - Mathematica, BlueJ, Greenfoot, Node-RED, Claws Mail, VNC Viewer
* Python Games and SmartSim added to Recommended Software
* VLC media player with VideoCore hardware acceleration included in image
* Version 3.0.5 of Thonny included
* Modifications to LXDE components to enable local configuration to override global configuration correctly
* Modifications to Appearance Settings to support above configuration changes
* Modifications to various initial config defaults and relevant package to support above configuration changes
* Selecting default option in Appearance Settings now deletes relevant local configuration files
* PiX theme modified so that all changes made in Appearance Settings are in override files rather than in theme files
* Design of scrollbar buttons changed
* Image Viewer moved into Graphics category on main menu
* Recommended Software now installs LibreOffice language support files if needed, and suggests reboot if needed
* Latest version of Pepper Flash plugin included
* Chromium h264ify plugin permissions set correctly by default
* Corrections to various MIME types so that files open in sensible default applications
* Set default timezone to 'Europe/London'
* Linux kernel 4.14.79
* Raspberry Pi firmware 12e0bf86e08d6067372bc0a45d7e8a10d3113210
Anleitung und Bilder an neues Image angepasst, Info zu neuem Image hinzugefügt.
Re: Raspberry Pi installieren: RASPBIAN Stretch (+Full +Lite)
Link zu den Release Notes der Images hinzugefügt.
